Just speed sensor problem? Or worse?
Old Jul 9, 2006 | 05:17 AM
Will5
Default Just speed sensor problem? Or worse?
Hello, I might be buying a 1990 Accord from someone I know.. They are getting rid of it pretty cheap but let me know ahead of time that the speedometer started acting up a while ago. It works sometimes, but others it just stays at 0 and when it does stay at 0 the transmission S light flashes. They thought it was just a speedsensor problem but aren’t really sure.
Does that sound like just a speed sensor or could it be something more? If just a speed sensor is that an expensive fix?
Thanks!
Old Jul 9, 2006 | 11:20 AM
mbo1985's Avatar
Default RE: Just speed sensor problem? Or worse?
Sounds like the speed sensor to me. Mine burnt out in my honda, so it seems to be a pretty common thing to go out.
Old Jul 9, 2006 | 01:04 PM
Hi Member..
Has anyone thought of just checking the speed-o-meter cable to see if its cracked or even broken?
Check it out!
Old Sep 12, 2006 | 12:37 AM
mbisenius
Mine does the same thing. I start it and start driving. The speedometer is at 0 and won't move. Then in about 2 or 3 minutes the green S starts flashing. Then about 2 minutes after that the check engine light comes on. I put a fire extinguisher in it just in case :-) I've replaced the TCU about a year ago. Any idears?
Old Sep 12, 2006 | 04:01 AM
Slusher's Avatar
I would recomend, first, do what WheelBrokerAng suggested, simple first. It does sound as though the VSS is out and it seems to be pretty common after a certain amount of time. VSS replacement is not too hard it is just in a hard to reach area, but nothing that should discourage you. I'm not sure of the procedure on you model or if its universal on most models but I would wait and hear from someone with your same year accord advise you on what goes into it.
Old Sep 12, 2006 | 05:00 AM
deserthonda's Avatar
http://techauto.te.funpic.org/vss.php
hope this helps
Old Sep 13, 2006 | 07:22 PM
Accordn2dis's Avatar
Default problem
same problem here
Afnan
Nov 19, 2013 05:52 PM
crshbandit
Nov 30, 2011 01:22 PM
thedaveman89
Nov 21, 2008 12:47 PM
noboundaries6289
Nov 9, 2007 08:00 AM
