key light?
Old Mar 27, 2012 | 03:30 AM
leeschof's Avatar
Default ECU light
Originally Posted by PAhonda
Your key is working, so the imobilizer is working properly.
It flashes a few times on my car when I remove my key. I think that the owner's manual says something about the imobilizer light. It will probably describe the normal function of that light, then tell you to get the car serviced if the imobilizer light does something different.
Post back and let us know what you find in the owner's manual.
I have a 1998 accord (CG9) the ign barrel wore out so replaced the whole thing and the black box immobilizer too,the car now will not start with the green light flashing. does the ecu need resetting to the new key? as i thought the immobilizer box told the ecu the key was correct?
thanks
Old Mar 27, 2012 | 08:25 PM
The ecu and the key have to be programmed to "know each other". You'll need a locksmith with the proper tools or a dealership
Old May 3, 2012 | 06:43 PM
klrspz's Avatar
Sorry I dind't reply, I didn't have any notifications set up...
yes, it's working as desired, as I described in my other post.
*whew*
csh217
Jun 17, 2014 05:53 PM
corlyf
Sep 12, 2012 11:30 PM
AKcord
Oct 15, 2006 07:43 PM
jrcastro
Jun 25, 2006 12:03 PM
eckhart
May 8, 2006 01:05 PM
