Keyless entry Install, Accord 95 Exi
Old Oct 26, 2014 | 09:30 PM
mortuzahasan's Avatar
Default Keyless entry Install, Accord 95 Exi
I bought a key less entry system and wanted to install it.
Car is Accord 95 EXI
i just need the basic door lock/unlock and parking lights flashing. also need
to keep the original key entry alive.
Can you please advice how to install and keep both system side by side.
Thanks in advance.
Old Oct 27, 2014 | 07:33 AM
djkurious's Avatar
Old Oct 27, 2014 | 05:55 PM
Thanks for your input.
I bought a crap one from HongKong and the wiring diagram is asking for lock motor connection. dont know where the hell is lock/unlock motor (2 wire)
Old Oct 27, 2014 | 06:02 PM
The door locks are negative (ground) trigger for your car.
You can connect the wires at the C425 connector (optional security system ) to trigger the door locks. The C425 connector is located above the left kick panel. It should be an unused grey colored connector that is already taped to another harness. You would cut the tape off to let it come loose.
The Blk/Wht wire on the connector pin is for the Lock input and the Orn wire is for the Unlock input. The C425 connector is for the optional Honda security system, it runs to the power door lock control unit and used to trigger the door lock and unlock feature with the security system. The power door control unit has other wiring and switches to still make it function without the security system.
stanley.ysf
Aug 23, 2007 07:42 PM
manual123
Nov 25, 2006 04:45 PM
Mpwr
May 31, 2006 11:53 PM
sastone75
Nov 18, 2005 08:38 PM
93Miata
Nov 10, 2005 08:06 AM
