knock sensor engine light still on after replacing
Old Aug 20, 2012 | 06:54 PM
understand1's Avatar
Default knock sensor engine light still on after replacing
I have a 2000 Honda Accord Ex I replace knock sensor and engine control module and engine light is still on. I keep getting the knock sensor code p0325. What should I do next.
Old Aug 20, 2012 | 07:59 PM
Start by initiating your own thread.
Is this a V6 or 4-cylinder?
Either you installed a faulty knock sensor or you have a wiring fault. To determine which you will need to disconnect at knock sensor and at ECM and check wiring for open or short on signal knock sensor wire or connector. It could be damaged wire or damaged connector at sensor.
Old Aug 20, 2012 | 08:02 PM
Dr. Drivability's Avatar
just enough information to completely ignore the post...
Old Aug 28, 2012 | 05:42 PM
Default Wiring problem
Does anyone know how to remove the wiring so I can replace it on 2000 Honda Accord Ex.
Thanks
tap500
Dec 2, 2013 09:36 PM
jaydev
Mar 26, 2012 09:18 PM
RSJ
Dec 14, 2010 07:54 AM
elessar78
Feb 4, 2010 03:30 PM
satutoring
Jul 28, 2009 03:41 PM
