Knocking noise
Old Jan 10, 2013 | 04:44 PM
srk's Avatar
srk
Default Knocking noise
Hi All, I am new to the forum, I have a Honda Accord Aerodeck 2.0 LSi 1995 and I have notice a knocking noise when the engine is hot and has been running a while. When starting from cold there is no noise however after driving a while the noise returns. I am not sure what to do and or how to solve the problem. I would welcome any suggestions or help. Many thanks and a happy new year. SRK
Old Jan 10, 2013 | 07:56 PM
I moved this into its own thread because it's really different from the one you posted in.
Old Jan 11, 2013 | 01:00 AM
UhOh's Avatar
well, not much to go on - first question here would be oil:
enough of it, right viscosity? Yeah, you'd have checked ...
Old Jan 11, 2013 | 08:29 AM
hondadude's Avatar
To check for rod bearing noise, lightly step on and off the gas to see if the knock changes.
Old Jan 11, 2013 | 02:07 PM
srk's Avatar
srk
Hi thanks for comments about the old I am using 75/90 transmission fluid should I be using different grade or viscosity, forgive if I sound naive but I had my honda for 10 years and its first time has occurred? thanks
Old Jan 11, 2013 | 02:55 PM
UhOh's Avatar
your complaint is about an engine noise
I looked this up once. 75W-90 (or was it 80W-90?) tranny oil has kinda the same viscosity as 10w-40 motor oil; different scales, confusing.
I have '97 and a '92 Accords, 4 cylinders. I use 5W-30 engine oil in the engine.
You're using kinda 10W-40 in engine, but with tranny service designation.
Don't know if this is big enough difference to make noise over time...
Old Jan 11, 2013 | 09:03 PM
I wouldn't use gear oil in the engine. There's a lot of different properties besides viscosity ranges.
Engines have a lot of sliding contact (journal bearings, piston rings). Meanwhile transmissions have more rolling contact (ball bearings & hypoid gear teeth). Engines have to deal with combustion products making the oil acidic, so there's additives to counteract that.
zoneout
Aug 24, 2009 06:30 PM
bigdawg74
Aug 20, 2009 11:38 PM
abwill30
Jun 23, 2008 09:16 AM
kingss
Mar 20, 2008 07:24 PM
FlyLow
May 8, 2006 06:00 AM
