Knocking Sound ???
Old Apr 20, 2009 | 10:01 PM
mejim707's Avatar
Exclamation Knocking Sound ???
Is this a rod knock or bad gas or thin oil or what? I've adjusted the valves to intake .254 mm and exhaust .301 mm. The knock goes away while driving, or under load, from what I can tell. I've read in other places that many people have had the same issue and have done amsoil engine flushes that have helped. The engine has only about 110,000 on it and the spark plugs are gapped correct, the wires are only a few months old and blah blah. I opened and cleaned the plenum, EGR system and checked vacuum on the hoses. The crank pulley wobbles and I'll be replacing that tomorrow, but, the outer pulley, the small one, is perfectly true. The outer one, separated by the rubber, wobbles prob due to the belt being to tight at one point thus smooshing the rubber. I baby this thing and from what I know have done everything to figure this out without dropping the pan and grabbing the rods, I'm not into that ya know. If I have to I will. Any ideas or HELP, PLEASE HELP, would be great. Thanks.
1999 Honda accord LX, 4cyl F23a4
Here's a youtube vid I did today right after getting home from work quite upset with this!
http://www.youtube.com/watch?v=Kj2thVW2odo
Old Apr 21, 2009 | 11:55 AM
mejim707's Avatar
Default Hardy Har Harrrr
Anybody? I've just picked up a new oil filter and some castrol syntec 5w 10 oil today for a complete oil change tonight. Please listed to the sound and make any comments you see fit. Thanks a lot!!
Old Apr 21, 2009 | 01:47 PM
5w-10 oil??
Old Apr 21, 2009 | 03:11 PM
mejim707's Avatar
Red face Hardy Har Harrrr
sorry, it was 5w 20. Correct? Castrol syntec. Were you able to watch the video? Does that sound like I should drop another engine in?
Old Apr 21, 2009 | 03:19 PM
I can't see U-tube from work...
Honda originally called for 5w-30, which is what your owners manual says. Then after a couple years they retro-actively changed it to 5w-20 for Accords beginning in 1998.
Old Apr 21, 2009 | 03:32 PM
mejim707's Avatar
Question
Yeh, I know they used to call for 5w 30 but wasn't that until about 97? 97 and after was 5w 20 wasn't it? What do you suggest? Would it be bad to use the 5w 20 for the summer?
Old Apr 21, 2009 | 04:05 PM
Where do you live - is it HOT?
If you're concerned, keep the 5w-20 for winter & use 5w-30 now.
Old Apr 22, 2009 | 09:25 AM
mejim707's Avatar
The knock is worse. I've changed the oil and the knock starts now at 1300 - 1500 rpm and now I can hear it between slow speed shifts. I'm very worried about this. It seems that no body wants to touch the video with a 10 foot pole either. BTW, I got the 5w 30 and put that in.
cerbera33101
Mar 15, 2012 09:29 AM
99accorder
Oct 5, 2011 05:47 PM
Moonraker7
May 6, 2010 09:31 PM
james_and7
Aug 28, 2008 11:29 AM
mbnjagn
Mar 13, 2008 03:20 AM
