"Light engine oil" to change fuel pressure regulator
Old Oct 3, 2019 | 08:49 AM
rockhoundrob's Avatar
Default "Light engine oil" to change fuel pressure regulator
1998 Accord- I plan to change the fuel pressure regulator.
The Chilton manual says to coat the O-ring with light engine oil. What is considered "light" ?
On other cars I've worked on, I just wiped new engine oil (5W-30) on the O-ring.
Old Oct 3, 2019 | 08:59 AM
shipo's Avatar
The 5W-30 you use will work perfectly well.
Old Oct 3, 2019 | 09:44 AM
Seanjordan20's Avatar
Any oil will do. Just dip your finger in the oil and rub your finger around the o-ring. You certainly don't need a lot to make the part slip in place easily
Old Oct 3, 2019 | 12:42 PM
Thanks guys... just wasn't sure if this was a critical issues or not.
5W-30 it is then!
djalmab
Jun 13, 2018 02:38 AM
RobinsonRicer
Jul 30, 2012 03:21 PM
techjohnny
Feb 20, 2011 09:22 PM
jamrock
Nov 14, 2008 02:17 PM
martinh
Aug 31, 2007 12:35 PM
