light problem
Old Jan 20, 2009 | 06:14 PM
neomaxim
Default light problem
So i just got into my honda tonight and realized that my speedometer/tach and all those lights are not working (although the high beem indicator,parking breeak,etc lights work. Also, the rear brake lights and license plate lights are out as well (brake lights do work when i press on brake). I was just wondering if anyone had any idea what could cause this or what I could do. Im new to Hondas and not sure where to start (possibly fuses?) Any help would be appreciated! Thanks!
Old Jan 20, 2009 | 07:32 PM
Default RE: light problem
It would help to know what year Accord (presumably though you don't say). Put in your signature line.
Underhood fuse box would be my first suggestion.
Old Jan 20, 2009 | 08:07 PM
cjdm98's Avatar
It may be more than one fuse..So i would suggest check them all.
And update your post with the correct vehicle information(Year make model),as well as signature information as well.
Old Jan 20, 2009 | 09:13 PM
neomaxim
sorry about that..forgot to mention those specs.
1995 honda accord EX
2.4 vtec
Old Jan 20, 2009 | 09:19 PM
cjdm98's Avatar
2.4 vtec?
Old Jan 20, 2009 | 09:22 PM
neomaxim
ah, 2.2 maybe? haha sorry.
Old Jan 20, 2009 | 09:45 PM
hondadude's Avatar
I knew it was a 95 2.2 all along, crystal ball was tuned up LOL
First check underhood fuse #32-15 amp
Next remove the steering column shroud [screws underneath]
On the plug to the headlight combo switch check for power [inbound]from the fuse on the RED/green wire.
Then turn on the lights and check for power[outbound] on the RED/black wire.
FWIW; those switches can be removed thencarefully opened and contacts cleaned and tension sprigs stretched a little bit.
Old Jan 22, 2009 | 04:03 PM
neomaxim
so i found the fuse that was broken and bought some new ones. ATC-15. everyone i put in blows the fuse. so im guessing a short somewhere? Also just wondering if there is any difference between ACT and ATM fuses. Thanks for any help!
Old Jan 22, 2009 | 06:27 PM
Try isolating the light dimmer in the dash (remove connection and install jumper between Red/Blk and Red wires on connector). If indicator lights burn full bright and fuse does not blow, you've found the problem, the dimmer control unit.
kellysa111
May 1, 2009 08:35 AM
ukcoupe
Oct 18, 2006 09:31 AM
bigdude
Oct 1, 2006 07:03 AM
hotrod01
Nov 11, 2005 01:28 AM
