losing fuel mileage???
Old Jan 27, 2014 | 01:39 AM
Soxxerms's Avatar
Question losing fuel mileage???
99 accord ex 302 plus on the mileage. was getting about 430 miles to a tank , then bamm blew timing belt.. so it was replaced, plugs, plug wires, distributor cap and mapp sensor. all replaced while i was on a roll to blow money.. now my car wont keep idol an im lost about 60 miles on the end of the tank in mileage. now getting about 330 to 350 a tank now , i am using non ethanol gas.
any thoughts?
sorry this is a 4cy motor with a 5 speed trans....
Old Jan 27, 2014 | 08:16 AM
Was cylinder head removed and valves repaired when timing belt failed? If not, you may have a bent valve leaking and causing problems.
Is check engine light on? What codes?
Old Jan 28, 2014 | 04:32 AM
Soxxerms's Avatar
Was cylinder head removed and valves re. ired when timing belt failed? If not, you may have a bent valve leaking and causing problems.
Yes new gasket only. no valves at the point was needed of repair. No light no codes thrown.
Old Jan 28, 2014 | 07:30 AM
A leakdown test or simply blowing air into each cylinder at TDC and determining where air is leaking can tell if valves are leaking. Noise of air escaping into intake manifold or exhaust pipe indicates valve problems. Some leakage into crankcase is normal.
See leakdown test on youtube if you're unfamiliar w/ test. richpin06a, ericthecarguy, and briansmobile1 are good sources.
Old Jan 28, 2014 | 09:44 AM
Soxxerms's Avatar
Awesome. Thanks for the heads up
JHeim81
May 22, 2011 09:41 PM
sir_nasty
Sep 25, 2006 04:24 PM
herzy23
Sep 13, 2006 11:20 PM
herzy23
Sep 13, 2006 06:05 PM
Triblade
Mar 14, 2006 02:06 AM
