Loss of power, car sputters/backfires
quote:
Even though the battery tested good could I still have a bad cell that would pass it as good?
Did you test it with a normal voltmeter? Or a load-tester? Or take it in to some car=parts store?
A battery with a bad cell can look OK if you're measuring with a normal voltmeter. That doesn't check it "under load".
Belt noise
Did you remove the power-steering belt completely then run the engine to rule out the PS pump or belt? Up to 2002 you can also remove the other belt (alternator & AC) and the engine will run just fine because the waterpump will still run.
Belts get hard & slippery with age. Don't over-tighten to compensate for that because that's hard on the bearings.
Belt noise
Belt noise
Belt noise
Battery's are supposed to be 12 volts right?
When I got home I tested it with a multimeter. I don't have a load tester.
EDIT
This is a picture of how loose the belt that's on the alternator is, I can flex it either way and it moves.
http://prntscr.com/57sl60
This is a cord that was under my dash on the drivers side, any idea where it goes too?
http://prntscr.com/57sly4
Sorry for the picture size.
Screenshot by Lightshot
jerome_dawg
Feb 9, 2012 06:10 PM
Janmarie
Jan 11, 2012 11:22 PM
mishakol129
Dec 12, 2011 03:57 PM
