94 accord 2.2L backfires at 2000 rpm
Old Oct 27, 2014 | 02:01 PM
Joe Johns's Avatar
Question 94 accord 2.2L backfires at 2000 rpm
Engine starts great, idles smooth. It bogs down & backfires at 2000 rpm. Installed new timing belt, cleaned EGR ports in manifold. No change. The manifold pressure at MAP sensor is reversed from what it should be. I have low vacuum at idle & high vacuum at higher rpm. (MAP sensor output actually decreases as I increase rpm). Worse News is I have check engine light & I can't pull the codes. I've tried by using a jumper with no luck. Auto Zone, Advance, O- Riley's say their stuff won't go back to '94 & they can't pull the codes. PLEASE HELP> I'm almost wishing I had a Ford.
Old Oct 27, 2014 | 03:39 PM
See DIY section on ECU/TCU/ABS codes procedure. This is fastest way to solve your problem.
Old Nov 11, 2014 | 11:20 AM
Joe Johns's Avatar
Thanks for the feedback but, I said that there are NO codes. The clue was that the check engine light is on. Haynes repair manual says that if you have check engine light with no codes, it's the ECM. And that's what it was. Bought a ECM on e-Bay. Fixed it. She's running like a pickle seeder. (that means running great)
Old Nov 11, 2014 | 11:56 AM
Glad you fixed it!
I interpreted your original posting as not being able to pull the codes and referred to procedure.
5TWENTY3
Nov 18, 2014 05:30 PM
jasonboes
Aug 2, 2012 12:45 PM
bnavarre
Dec 3, 2008 07:42 PM
wallc777
Nov 27, 2006 02:52 AM
rottevnm
Aug 17, 2006 09:59 PM
