Lost turn signals and hazards
Hello I have a 1999 Honda Accord and all of a sudden the turn signals and hazards stopped working. Checked all fuses r good and replaced the turn signal/hazards relay and still have nothing doesn't make a noise or do absolutely anything. Anyone experience this issue before and know how to fix? Thx
The turn signal and hazard lights all go through the hazard switch. If you have a test light, you may want to check for powers and grounds on the connector for the hazard switch. Search youtube for DIY 1998 2002 Honda Accord Clock light bulb replacement to see how to remove the hazard/clock.
My 95 accord had a similar setup. I replaced the switch and it fixed my problem. I was just learning how to work on my car, so I suspect that I could have cleaned the contacts in the switch and would have had a working hazard switch.
I figured it out my dad suggested to check hazards and did and found out that the 2ed plug that is in back of switch was unplugged and the 1st didn't make good connection so I taped them together and hopefully they stay. I also noticed that my reverse lights r linked to it also and they work again too. I hope this tread helps someone else. The roads sux up north here so the vibration made them disconnect at some point. Thx for the help.
