Low Fuel Light
Old Aug 19, 2008 | 08:54 PM
Lance Link's Avatar
Default Low Fuel Light
1999 4-Door EX V6, ~117K miles
My low fuel light indicator has not worked for months. I can live without it, but it would be nice to fix it.
Does anyone have any suggestions, tips? I'm really hoping I don't have to get behind the cluster panel.
Thanks.
Old Aug 20, 2008 | 09:04 AM
Fenix's Avatar
Default RE: Low Fuel Light
Umm, most likley your going to have to get back there to change that bulb. Just my thought
Old Aug 20, 2008 | 09:46 AM
Aquariumjunkie's Avatar
ORIGINAL: Fenix
I Agree, your gunna have to replace the bulb. getting behind the cluster isn't hard at all.
Old Aug 20, 2008 | 10:03 AM
It might be the sender back at the gas tank?
Old Aug 20, 2008 | 10:10 AM
On a 99 accord, does the fuel light typically turn on for a second when the key is first turned to the II position? I know that the 5th gen Accord fuel light does not turn on at the II position.
Before you replace the bulb, you should be able to test the fuel sending unit. You should be able to short a connector at the fuel sending unit, and the low fuel light should turn on. I don't know which pins to short, but a shop manual will have those details.
Old Aug 20, 2008 | 10:18 AM
I used to have a 98, and I recall the fuel warning lamp does NOT light up during the bulb-check.
That warning lamp is not under the control of the ECU, it just has a contact-closure at the fuel sender. So its like the oil pressure lamp. Butthe oil pressure lamp comes on simply because the oil pressure IS ACTUALLYlowbefore you start the engine.
Old Aug 25, 2008 | 12:08 PM
Lance Link's Avatar
Thanks.
I haven't taken off the panel before. I guess it's time now.
kennylogsdon
Feb 8, 2012 12:56 AM
HondaAccordNewb
Oct 18, 2007 06:51 AM
IWL BCNU
Sep 13, 2007 05:35 AM
shaleck
Jul 28, 2007 06:55 PM
bigjayzizzle
Jun 3, 2007 10:35 PM
