Low Idle
Old Jun 28, 2009 | 05:05 PM
jonsolis's Avatar
Default Low Idle
I drive a 2001 accord automatic and lately my rpm has been idleing really low. Around 500 or so. It feels like its gonna stall when im come to a stop or when i am at a complete stop. I've been asking around to see what could be the problem. When i first start the car its fine but once it warms up its back to the same old thing again. I thought it would be the motor mounts but again, im not too sure. Please if anyone knows what the problem could be, PLEASE PLEASE let me know! Thanks very much!
Old Jun 28, 2009 | 05:27 PM
Smile Hi New Member
Welcome to the HAf..Thank You for joining..
You posted your question in the wrong forum...so I moved you to this
forum..good luck in here..
Old Jun 28, 2009 | 06:50 PM
Usually this can be fixed w/ a good cleaning of throttle plate (both sides) and bore of throttle body around plate. Use throttle body cleaner. Wipe clean w/ paper towel.
Also clean idle air control valve movement w/o dousing the solenoid w/ throttle body cleaner as this may damage the windings. Check that idle air control valve works w/ 12V and ground applied directly to connector lugs. It should open w/ 12V and spring closed when voltage is removed.
CD7jay
Oct 28, 2009 01:11 AM
ItsNewToMe
May 3, 2009 07:20 AM
Nitin
Apr 20, 2008 07:19 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
thunder_x
Sep 25, 2006 09:34 AM
