Low MPG, at a loss
Old Jul 20, 2010 | 04:12 PM
Tippman7641's Avatar
Default Low MPG, at a loss
So I have a 1999 Accord V6 with 167K miles on it.
note: I just spent about an hour searching google and other forums and couldn;t get a straight answer
It seems no matter how I drive( i mostly drive highways) I get about 20mpg, actually thats what I get no matter what. Everyone else says they get about 28
I have or it feels like i have the same torque and acceleration I've always had, sometimes it dosent give much torque until the v-tec engages(rarely happens)
My plugs look in good shape(NKG), they are gapped at .40
my air filter is slightly dirty
I'm not entirely sure but i think its a clogged injector, but i want some opions before i go and rip off the intake manifold cause that is a big pain
Also idk when the plugs where last changed, could they casue that steep of drop in mpg?
Thanks for anyinput
Old Jul 20, 2010 | 07:42 PM
kris_loehr's Avatar
I would suggest starting with seeing if there are any codes stored in the computer, some of the automotive parts place will run a check for free. Gas mileage seems to have always been a mystery. I would think one injector to be bad enough to cost 8 miles per gallon would give you an engine miss. I would have to see the spark plugs to give any kind of answer on that question, but if you have no codes I would do a tune up, check the tire inflation and start there. When did the mileage drop off? The trans is shifting into overdrive if you have an automatic
cukaracha
Aug 22, 2014 12:52 PM
Taurus1980
Sep 23, 2013 01:30 PM
Capt NoSkillz
Mar 9, 2009 04:51 PM
Accord Owner
Jul 6, 2008 11:07 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
