Lower ball joint replacement
Old Oct 31, 2010 | 08:13 PM
elvis1977's Avatar
Default Lower ball joint replacement
I have a 98 Accord 4-cyl. with 201k miles. I am the original owner and the lower ball joints are original. One boot (dust boot) on the passanger side has a hole in it and is leaking slightly. With 201k miles should I go ahead and replace both lower ball joints or just replace the dust boot that has a hole in it? I'm planning on keeping the car forever. Thanks.
Old Oct 31, 2010 | 08:43 PM
I'd probably think about replacing the whole balljoint where it was torn, because dirt probably got in there. Look at the boot real carefully. If it looks like it came apart from age or dry-rot, then absolutely change the boot on the other side. Other balljoints too. If it's clearly torn by some tool, then it's less panic.
I'd still check out the opposite side real good.
Old Oct 31, 2010 | 09:04 PM
elvis1977's Avatar
The boot has a small puncture hole only on passanger side. The driver's side boot was replaced by a honda dealer at 120k and still looks good. At 201k miles should I just replace both lower ball joints and be done with it? I plan on keeping the car forever. I'm glad I finally found you again "GREAT WIZARD"!
Old Oct 31, 2010 | 11:18 PM
I would replace the ball joint if it is loose. If there is little play, I would replace the boot. Clean out the old grease, add some fresh grease, then put a new boot on there.
sgull
Aug 23, 2013 01:47 PM
barbers
Aug 14, 2013 01:13 PM
shome
Aug 16, 2007 10:54 AM
PAhonda
Jul 10, 2007 04:40 PM
Hondaccord
Nov 4, 2006 06:30 PM
