Lower Control Arm Bushing Removal/Replacement
Old Dec 29, 2012 | 03:51 PM
Colondo's Avatar
Default Lower Control Arm Bushing Removal/Replacement
Hey all,
I was attempting a cv axle replacement for my 2001 accord lx 5-spd no abs. The axle will not fit through the wishbone so I attempted to remove the lower control arm bushing bolt. The bolt head snapped inside the bushing, so now only one side is supported by the bolt. I have used a puller/pusher to try and get the remaining bolt out to no avail. Honda mechanic suggested burning the bushing out. Does that sound accurate or is there another way to do this?
Picture shows screwdriver separating wishbone from broken bolt stud.
Thanks,
Brian
Old Dec 30, 2012 | 08:28 AM
I think you are fighting the knurl on the bolt. try cutting the nut off and push it the other way.
Old Jan 25, 2013 | 09:58 AM
Colondo's Avatar
Been a while, but the job is done. When I have time I will post what I consider to be a "real" experience as a home mechanic without air tools, etc. It involved replacing both CV axles, both lower control arms, and both sway bar links since everything was easily accessible.
DJ NVS
Dec 17, 2009 07:41 PM
spudman49
Oct 13, 2008 02:47 PM
mtnbay
Jul 20, 2008 03:22 AM
Steve93
Oct 19, 2007 05:02 AM
hkbballboi
May 18, 2007 05:41 PM
