lowering an 09 v6 coupe
Old May 9, 2012 | 06:03 PM
Brendan Foley's Avatar
Default lowering an 09 v6 coupe
i have a 09 v6 coupe i plan on lowering myself, can someone just fill me in on if a camber kit is necessary ? or can i pick up some new struts and eibachs.. and if anyone knows i site to get good priced struts lemme kno. thanks
Old May 9, 2012 | 06:16 PM
For your aftermarket lowering questions, there is driveaccord forum which has members that add aftermarket suspension. We can help you with many other questions regarding your car; however, there are not a lot of member on this forum with 8th generation Accords that they modify and give first hand advice. I have an 8th gen; but, don't modify.
If you were using an HFP (Honda Factory Performance) suspension kit, then I do not believe you need a camber kit.
Mods: Delete my post if it is not appropriate. Just trying to give helpful advice.
Old May 9, 2012 | 07:13 PM
Shawn8020's Avatar
I have an 11 Accord Coupe lowered with Eiback Pro Kit Lowering springs only, its been 4000+ miles since and there has been no noticeable uneven tire wear. Although without high performance struts the ride is really bouncy and I will be soon switching to Tien coilovers. I have heard that you may need a rear kit.
Here read this:
No, you DO NOT need camber kits!!!!!!!! - Honda-Tech
cesar408
May 5, 2015 11:20 AM
maxman
Jan 14, 2013 09:51 PM
byebye2u
Dec 8, 2012 04:03 PM
ucftennis12
Dec 16, 2008 02:40 PM
stefanb21487
Dec 7, 2007 10:27 PM
