Lucas Anti Slip in 04 Accord
Old Jul 6, 2011 | 01:24 PM
sawtooth500's Avatar
Default Lucas Anti Slip in 04 Accord
I have an 04 Accord with a V6 engine and about 105k miles. My tranny is beginning to slip so I was going to pour in a can of tried and true lucas anti slip in there. Some mechanic told me not to do this as my tranny would be dead within 2 days if I did - i've used lucas on others cars with great success in the past. Is it ok to put lucas in my tranny fluid or will it royally mess up my tranny as this mechanic claims? Also, I should probably just change out my tranny fluid all together, you should only use the Honda ATF, correct?
Old Jul 6, 2011 | 02:15 PM
I would try changing the transmission fluid first with Honda ATF.
You will drain about 3 qts of ATF, refill, then drive. See if you get an improvement. Look at the old ATF for metal shaving, color, burnt smell, etc. Clean off the crap on the magnetic drain plug.
You should do the drain/refill/drive a total three times to exchange most of the fluid.
Old Jul 6, 2011 | 04:57 PM
If the tranny still slips after changing the fluid, is it ok then to put lucas in it? I just want to make sure the lucas won't damage it....
Old Jul 6, 2011 | 05:21 PM
I never owned a Honda automatic transmission, so I don't know what Lucas anti-slip will do. There have been threads on here where simply changing the ATF helped out tremendously.
across55
Nov 5, 2009 12:36 PM
Jmoney
Jun 1, 2009 10:03 AM
xaznxeclipsex
Nov 5, 2007 04:45 PM
Mar 31, 2007 02:03 AM
nixalot
Jun 10, 2006 05:28 AM
