Main fuel pump relay on gen 9 4cyl lx
Old Dec 14, 2023 | 02:27 PM
3TRider's Avatar
Default Main fuel pump relay on gen 9 4cyl lx
Wife put diesel in our Accord. I would like to run fuel pump to drain tank, but don't know which relay to bypass.
Old Dec 14, 2023 | 04:43 PM
The relay will likely be PGM-FI Relay 2 based on the previous generation accord. Looks like key will need to be in the II position to power the + side of the load circuit.
Old Dec 14, 2023 | 05:10 PM
3TRider's Avatar
Thank you for responding. Do you know where that relay is located? One person said it was on engine compartment panel. When I jumped that relay there we 4 clicks and the pump ran for 2-3 seconds then cut out. Another person said it was under the dash behind the cruise control module, but I can't identify it.
Old Dec 14, 2023 | 05:32 PM
I'm working off a 2010 shop manual. I is likely in the under dash fuse box on the driver's side.
Hidden lights
Mar 3, 2015 06:39 PM
dr.honda
May 10, 2012 11:46 PM
fastdart360
Jan 24, 2008 07:52 AM
ohccord
Dec 8, 2006 12:25 AM
longneck8769
Apr 3, 2006 02:12 AM
