Maint. Required Light Stays ON After Reset
Old May 2, 2007 | 05:22 PM
jdh72022
Default Maint. Required Light Stays ON After Reset
Have an '03 Accord with 62K miles. Been regularly serviced. Usually light only flashes before I have oil changed and reset it. This time, it came on solid and stayed on, even after I push the trip od. button while turning on the key. It blinks then comes right back on. Tried it several times. What gives? Been through 2 oil changes now and it still won't reset. Any suggestions?
Old May 2, 2007 | 06:21 PM
Default RE: Maint. Required Light Stays ON After Reset
https://www.hondaaccordforum.com/Can...m_55059/tm.htm
read that thread
Old May 3, 2007 | 02:07 AM
That thread talks about a newer one with the maintenance computer. That's different.
I bet you just didn't hold the button for long enough after turning the key ON.
Old May 3, 2007 | 11:43 AM
jdh72022
I don't know how much longer I can hold it in. The light does go off, I can even hear a relay clicking at the time, but within a second, it comes back on. The first suggestion given by PAhonda, though appreciated, did not work either. Any other suggestions? I'll try anything.
MikeMoss
Dec 3, 2011 08:04 AM
inno87_2k_accord
Oct 12, 2010 07:06 AM
mracman1
Apr 10, 2009 02:01 PM
hotrod01
Nov 11, 2005 01:28 AM
