Malfunction Indicator Lamp On
Old Jun 19, 2008 | 05:05 PM
Default RE: Malfunction Indicator Lamp On
Try the LAST POST button. Or try expanding it with the [+] button. The whole site has been acting strange for a while now...
Old Jun 19, 2008 | 05:25 PM
The 98-00 accords have a different setup than the 90-97 accords. You will have to remove the throttle body and unbolt the upper part of the manifold (#10 with red circle around it). I don't think that you can access that passage easily from the EGR valve side, but you can always try.
That bore through the manifold is the EGR passage that gets plugged up that has the red highlight on the pic below. The honda dealership has a kit to help prevent that passage from getting blocked up for the V6 engine, but I don't know if there is a kit for the 4 cylinder engine. I would call a dealership and ask them about it.
I think that you would have to drill out the passage and insert a steel sleeve into that passage if the kit is available. Or use brake cleaner and a pipe cleaner to get all of the carbon out from there.
If you do this procedure, you should get a new gasket #11. The Air control valve might have to be unbolted from the back of #10 (not shown in that pic but I put a green circle around where it is mounted).
You might have to drain the antifreeze from the system before you start, or you could keep a rag and a pan under that area of the car if antifreeze is routed through the throttle body to the air control valve.
[IMG]local://upfiles/5767/E0FBE68E4BBF4EE4BFA4472F7F471772.jpg[/IMG]
Old Jun 19, 2008 | 05:34 PM
Ron505's Avatar
Thank you very much kind sir. I honestly appreciate the info. I will do as you've described.
choochoo
Oct 13, 2008 03:14 PM
pham9006
Mar 22, 2008 12:04 AM
tce23233
Dec 22, 2007 11:26 AM
blahblah
Mar 18, 2007 02:33 PM
djsinister
Mar 1, 2006 03:11 AM
