malfunction indicator lamp
Old Aug 19, 2011 | 02:52 PM
harry honda's Avatar
Default malfunction indicator lamp
Hi all just bought an accord 2.0i se exec 2000 plate,been driving for 5 days and this lamp came on!!!! What does it mean and what should i do to fix it? any advice or tips appreciated.
Old Aug 19, 2011 | 04:00 PM
It means the engine computer detected a problem and stored a code specific to the problem. I don't know if the parts stores where you live scan for codes as a free service.
Once you get the code, you can post it on here and we can help you out.
Old Aug 19, 2011 | 04:26 PM
Thanks PAhonda well i know a chap who may be able to scan it when he does ill get the fault codes on. To change the subject do you know if aerial on these cars are automatic as this one is broken lookin to get it fixed also?
Old Aug 19, 2011 | 04:41 PM
The antenna is probably powered. Starting in 1996 in the US, the antenna was part of the rear windshield.
If you hear a motor sound when you turn on the radio, then it is powered. If the antenna retracts near the gas tank lid, then you can pull back the inside trim in the trunk to see if there is a motor.
Old Aug 20, 2011 | 02:20 AM
I'll check it out thanks for the help.
Ron505
Jun 19, 2008 05:34 PM
pham9006
Mar 22, 2008 12:04 AM
tce23233
Dec 22, 2007 11:26 AM
blahblah
Mar 18, 2007 02:33 PM
djsinister
Mar 1, 2006 03:11 AM
