Manual Shifter Reverse Lockout
Old Oct 26, 2007 | 05:11 PM
kbunting
Default Manual Shifter Reverse Lockout
My son has 2000 Accord ULEV 4 door sedan EX model with 5 speed manual transmission and 4 cylinder motor.
Last night he could not get reverse but all forward gears work fine and shift smoothly.
Honda told him this was common with Accords and that there is likely a burr on the reverse lockout mechanism of the shifter.
Has anyone experienced this and can a do it yourselfer fix this at home?
I restored my Corvette but have never worked on his Honda.
Hethinks the shift mechanism can be removed from the transmission without removing the motor and transmission from the car.
Any suggestions on what th eproblem is here and how to fix it without getting the dealer involved?
Thank you in advance,
Kurt
Old Oct 27, 2007 | 08:25 AM
kbunting
Default RE: Manual Shifter Reverse Lockout
Anybody here????
Old Oct 27, 2007 | 10:31 AM
smaglik's Avatar
weekends are slower times on this board...apparently most people do this when they should be working...just be patient.
Old Oct 27, 2007 | 06:56 PM
Chiovnidca's Avatar
ORIGINAL: kbunting
I've never heard of that. Sometimes the gears dont line up right and you have to put it in another gear first to help line em up. Or let the car roll a little.
Old Oct 29, 2007 | 11:37 AM
00AccordLX5spd's Avatar
Registered User
Have you tried letting the clutch out a little bit to enable it to go into reverse - sometimes mine doesn't want to go into reverse and I have to do this. Also try shifting to 5th (stopped) then pull it down into reverse with the clutch still depressed.
Cheeva316
Oct 19, 2011 06:33 PM
Max Utility
May 19, 2011 12:32 AM
saanich
Sep 29, 2009 02:41 AM
etodak
Aug 3, 2008 07:37 PM
twoaudio
Jun 10, 2008 07:45 PM
