Message center lights blink randomly??
Old Aug 26, 2011 | 11:10 AM
trucknut88's Avatar
Default Message center lights blink randomly??
I have a 1991 accord lx. 216000 miles on it and recently the lights in the dash that tell you if a door is open or a brake light is out started blinking randomly. Mostly in the morning and maybe when the air is damp. Does anybody have an idea what is going on? I checked the body ground and cleaned it, the one right off the battery. Is there another body ground that could be causing this or is it something else. Car does not run any different when blinking occurs.
Thanks
Old Aug 28, 2011 | 09:56 PM
I'd start looking for bad grounds elsewhere in the car, especially back at the taillight clusters.
How do the interior lights work when you open the doors? Each door has a little switch that grounds the lamp circuit, and those can get flaky with corrosion.
Old Aug 29, 2011 | 06:42 AM
trucknut88's Avatar
All the interior lights work great. I will check the grounds in the rear lights.
Thanks
Old Aug 29, 2011 | 08:39 AM
I don't have a wiring diagram for 1991, so can't really guess which (if any) additional grounds might be involved. Finding flaky grounds can be a PITA so good luck.
The_OS
Jun 4, 2010 04:31 PM
jackkpts
Aug 28, 2009 03:32 PM
kornfox
Mar 3, 2009 11:50 PM
shahk
Nov 12, 2006 02:27 PM
