Misfire after doing a bunch of repairs... (1998 4cyl)
Old Jul 2, 2012 | 08:40 PM
KaboomCult's Avatar
Default Misfire after doing a bunch of repairs... (1998 4cyl)
Car: 1998 Accord EX 4 door, 4 cylinder, Automatic, ULEV
So over the weekend I did upper and lower ball joints as well as a wheel bearing. I Also replaced the flex pipe and cat to repair an exhaust leak. The day I replaced the exhaust parts I got a misfire code (the car was running ok) but figured it might be due to the exhaust leak.
Today (one day after the repair to the exhaust) on the way up a steep hill the car started running ruff and tripped the flashing CEL. It tripped a P0300, P0303 & P0304
I replaced the plugs and wires today, the cap and rotor are new a couple months ago. the plug from the #4 cyl was very black the rest looked ok. The car is still running rough.
What should I check next?
can a bad ICM or coil cause just a cyl or two to misfire.
it really sucks to have spent all this time and money just to have it run worse! PLEASE HELP!
Old Jul 2, 2012 | 09:16 PM
Double check the firing order of the plug wires.
See my post #11 in this thread:
https://www.hondaaccordforum.com/for...d-48527/page2/
Old Jul 2, 2012 | 09:20 PM
KaboomCult's Avatar
I am 99.9% that they are correct. I replaced one wire at a time as to not confuse them... I can double check tomorrow.
Assuming they are correct what would you check next?
Old Jul 3, 2012 | 08:09 AM
KaboomCult's Avatar
I triple checked the wires.... I am now 100% they are correct...
Old Jul 3, 2012 | 08:51 AM
Silver6gen's Avatar
How does your rotor and cap look?
Old Jul 3, 2012 | 09:17 AM
KaboomCult's Avatar
Cap and rotor both look good, they were new a couple months ago...
I think I am going to try to wrangle up a compression tester today and see what I come with...
Old Jul 3, 2012 | 04:48 PM
KaboomCult's Avatar
Default ompression test results are in
Well the compression test results are in and its not looking good...
cyl 1 = 210
cyl 2 = 190
cyl 3 = 210
cyl 4 = 30
How can I trouble shoot further? bad valve? rings? ect.??? I am at the point of wondering if fixing it is worth it. I am a capable back yard mechanic but have never got into motor stuff much.
the car has about 215,000. the trans was rebuilt about 2 years ago. I hate to junk it if I can fix it... I want it to LIVE ON!
Old Jul 7, 2012 | 10:49 AM
KaboomCult's Avatar
No one has any insight on this?
Old Jul 7, 2012 | 10:58 AM
Suggest checking clearances on #4 valves. Excessive gap would indicate a bent/stuck valve or carbon causing incomplete closure.
A leak-down cylinder test will confirm where the compression is being lost; valves (intake or exhaust) or by cylinder rings.
A cruder test is to install oil into #4 and see if compression increases temporarily. If yes, then leak is likely past rings. If no, then valves.
Also suggest repeating cylinder #4 compression test in case you made an error in gauge hookup.
JonJon13926
Mar 22, 2013 07:57 PM
powerslave
Jul 31, 2012 03:09 PM
pancho88
Jan 22, 2012 08:13 PM
anneinct
Jun 6, 2009 10:23 PM
jarede7
Aug 31, 2008 04:45 PM
