Misfiring????
Old Nov 15, 2006 | 05:16 PM
sir_nasty's Avatar
Default RE: Misfiring????
Doesn't that indicate a coil or ignitor problem and not neccessarily a misfire? That is the same code used on older vehicles so unless an older car could detect it then I would assume that post 94ish when the implemented the new ECU's is when that feature was added... This is just a wild guess based on various data so I could be mistaken however it makes sense to me so I'm going to run with it *L*
88-95 Civic
88-95 Prelude
94+ Integra Ignition Output Signal missing or defective ignition output signal Code 15
Old Nov 15, 2006 | 07:12 PM
Code 15 indicates a problem in the circuit where the ECU tells the ignitor to fire the coil.
Any misfiring caused 'downstream' of that point (for example bad plug wires or broken dist.cap) won't be detected under code 15. It might throw code 1 or 43 if the misfiring is REALLY bad - bad enough to cause measurable excess air in the exhaust.
OBD-2 cars have a crank-fluctuation sensor that measures the crank slowing down due to the misfiring.
YeuEmMaiMai's Avatar
mid 95 accords and 96+ were obdII or better
Old Nov 15, 2006 | 08:47 PM
sir_nasty's Avatar
sounds like it's settled then... a 94 accord wouldn't throw a cel for a misfire.... mid 95+ OBD-II vehicles would though....
Old Nov 15, 2006 | 08:52 PM
deserthonda's Avatar
ORIGINAL: JimBlake
egoman
Sep 25, 2006 09:50 PM
mbo1985
13
Apr 23, 2006 01:39 PM
Stab
Nov 14, 2005 02:28 PM
nemesis3
Aug 5, 2005 05:06 PM
1991hondaaccord
Aug 2, 2005 05:48 PM
