Mobil1
Old Jul 18, 2006 | 05:32 PM
vistin's Avatar
Default Mobil1
I have a new Honda Accord with auto trans and four cyl engine. I am going to change oil to Mobil1 10W30 synthetic soon. Has anyone done this?
37 MPG hwy 34 town.
CR
Old Jul 18, 2006 | 11:03 PM
deserthonda's Avatar
Default RE: Mobil1
Welcome to HAF.........
so what is exactly your question?? if using mobil 1 is ok ?? or do you need directions on how to change the oil and filter ??
if it is to ask about mobil 1 ,,,,,,,,,,,yes go for it , mobil 1 will be very good for your car .. you will need about 4.5 qts ..assuming you change the filter which you should do everytime you change oil
Old Jul 19, 2006 | 12:11 AM
longhornjohn's Avatar
Default RE: Mobil1
I removed the 5W-20 oil/filter at 2,340 miles (as I remeber). I put in Valvoline 10W-30 petroleum base to continue the engine break-in. I will change that out to Quaker State synthetic 10W-30 at about the 5,000 mark. I had planned on using Mobil 1 as my first synthetic, but I have been able to buy the QS for $1.99 after rebate. I now have 18 quarts in stock.
I checked out all of the synthetic 10W-30 oil specifications and there is virtually no difference in them as far as I can tell. And at that price I can drain it at 4,000 miles.
Old Jul 19, 2006 | 03:16 AM
lightshow's Avatar
Default RE: Mobil1
except that Qs is a dino base oil. because of the level of refinement it is allowed to call itself synthetic. but still when it is mixed with the byproducts of combustion, it will still create "sludge"
mobil 1 is a true pao base oil, that just doesnt have what it takes to make sludge.
Old Jul 19, 2006 | 11:08 AM
vistin's Avatar
Default RE: Mobil1
Thanks for the info. My original question delt with question about using M1 syn 10W30 oil. This isnt too thick is it? But reading on in more posts I find many of ya'll do change to this weight oil. So, you have answerd my question.
Thank you
CR
Old Jul 19, 2006 | 11:42 AM
RTexasF's Avatar
Super Member
Default RE: Mobil1
As we know 5W20 is recommended but not essential. Were it me I would use 5W30 as opposed to 10W30.
Old Jul 19, 2006 | 07:11 PM
nixalot's Avatar
Default RE: Mobil1
Just my opinion... but I wouldn't put Quaker State motor oil in a lawnmower... I have seen first hand the inside of an engine (as well as others in here I'm sure) that has had a steady diet of Quaker State... not a pretty sight... [sm=badidea.gif]
Old Jul 19, 2006 | 10:23 PM
mbo1985's Avatar
Default RE: Mobil1
Yeah I use 5W-30 mobil1as opposed to 10w-30. As far as mobil1 goes, I wouldn't use anything besides it.
Old Jul 20, 2006 | 03:12 AM
lightshow's Avatar
Default RE: Mobil1
the larger the difference between the first and second numbers on the bottle........the less durable the oil is, because there is less actual oil and more additives. i just posted an absolute gem of an oil write up, everyone interested in oil should read it in its entirety.
johnb06accord
Oct 23, 2008 07:03 AM
crvone
Jan 21, 2008 02:27 PM
vistin
Aug 16, 2006 04:40 PM
