Moisture in turn signals
Old Oct 11, 2013 | 05:01 PM
94ex915's Avatar
Almost A Senior Member
Default Moisture in turn signals
Been having this problem ever since I swapped my turn signals in the bumper. It only seems to happen to the passenger turn signal. I haven't gone through water or anything but it builds up moisture and the turn signal goes out. Any solutions to this?
Old Oct 11, 2013 | 08:58 PM
It has to be a seal in that bulb that is getting moisture. Repair or replace that turn signal housing. It is pretty simple to remove. You can probably pick a replacement at a u-pull-it junk yard for pretty cheap.
Old Oct 13, 2013 | 11:41 PM
94ex915's Avatar
I ended up using the old housing for the bulb. The o-ring on the new one seem to be cracked. Hopefully this fixes it. Thanks.
Monkey Joe
Feb 17, 2013 08:57 PM
tmarch
Apr 23, 2012 02:59 PM
gliff159
Apr 27, 2007 03:40 PM
kennilope
Jan 26, 2007 03:14 PM
jrschmank
Jun 4, 2006 07:13 PM
