Moisture inside cylinder
Old Dec 26, 2012 | 08:47 PM
Monkey Joe's Avatar
Default Moisture inside cylinder
I was driving today in the heavy carolina rain, when I drove through a large puddle of water. I did hydrolock my engine, it shut itself off and I coasted off the road. I had my vehicle towed back to my barracks. I have since removed the spark plugs and rotated the engine, allowing a good amount of water to exscape out. I have fuel, spark and timing are good. I still have moisture inside the combustion chamber.
How can I remove the remaining water out?
Can it be done be hand without the use of electrical or air-compressed tools?
I feel very sad for my honda.
Old Dec 26, 2012 | 08:59 PM
Old Dec 26, 2012 | 10:41 PM
basket_case's Avatar
Although I didn't hydrolock my engine, I had to remove water from the cylinder when the head gasket went and there was enough water in at least one cylinder to prevent the engine from starting. I removed the spark plugs, ran each piston to the top of the stroke (you can rotate the power steering pulley to do this when all the plugs are out), then used my shop vac to suck as much water out as I could. I had to adapt the 1.25 inch hose down to about a 5/16 vinyl tube (think duct tape and PVC fittings). Then, turn on the shop vac, stuff the little tube in the cylinder and move it around to suck out the water. Worked for me.
Old Dec 26, 2012 | 11:29 PM
Good post to remember members, this happens quite often it seems..Remember where you saw this post.
Old Dec 27, 2012 | 12:33 AM
jroxz44's Avatar
Almost A Senior Member
I normally just pull the plugs then hold the starter on for a while. The compression should push most of the water out. Me and my Buddys do alot of mudding in our jacked up trucks and this is a common thing to suck water in a mud hole. Spray alittle starter fluid down in the cylinder let it dry and put the plugs back in and it should fire. Dry your air filter out also
Old Dec 27, 2012 | 07:29 AM
Monkey Joe's Avatar
Thanks for all the helpful replies, I will work on my car this evening and update from there.
Old Feb 17, 2013 | 07:10 PM
Monkey Joe's Avatar
I forgot about updating. Car is good, problem fixed.
Old Feb 17, 2013 | 08:57 PM
Well, was it just a drying-out process? WAS there water in the cylinders? Did it come out by cranking with sparkplugs removed? Details, details...
94ex915
Oct 13, 2013 11:41 PM
tmarch
Apr 23, 2012 02:59 PM
HondaAccordEX94
Apr 5, 2010 04:27 PM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
