Moon roof motor doesn't stop
Old Sep 5, 2013 | 04:38 PM
jrock24's Avatar
Default Moon roof motor doesn't stop
My 94's Moon roof has this issue. If I go to open it all the way, once the glass is fully retracted the motor keeps turning. It also does that when it is closed. ANyone know how to fix this?
Old Sep 5, 2013 | 11:12 PM
The wiring diagram isn't clear on how the motor stops when opening or closing.
I would probably try picking up the moonroof switch from a junkyard and swap out the switch. I am not a fan of suggesting throwing parts at a problem, but the switch is very easy to replace. Picking up the switch at a U-Pull-It junkyard will likely cost you less than $10.
Old Sep 6, 2013 | 03:15 PM
jrock24's Avatar
You mean the dash switch, right?
Old Sep 6, 2013 | 03:18 PM
I suspect what tells the motor to stop are limit switches in the motor assembly. Kinda like the switch assembly inside a wiper motor that tells the wipers where to park when you turn them off.
Manpants
Apr 7, 2009 12:38 PM
Jeff247
Mar 31, 2009 05:14 PM
Calevra18
Sep 11, 2007 07:00 PM
2002haccord
Apr 12, 2007 11:43 AM
Cr8zychinamin
Jan 13, 2006 06:17 PM
