Sponsored by:
Sponsored by:
More Power
Old 10-09-2011, 07:53 PM
Pizzle_00's Avatar
Default More Power
2000 Honda Accord Coupe EX 2.3L AT
Lookin to boost my 135 HP
Where can I get the most bang for my buck?
Old 10-09-2011, 10:12 PM
whiskerz's Avatar
depends on your bucks , The old adage of speed cost money how fast do you want to go. I would not be afraid of some parts used like intakes and headers
Old 10-10-2011, 12:44 AM
Yes it all depends on the money game.It also depends if your going to use this car as a daily driver or not.
Blower superchargers, larger fuel system with custom fule rail, intake pipe and header, high output ingnition system and the list goes on...
Old 10-10-2011, 05:05 AM
piggylover1985's Avatar
I thought the EX came with 150hp ? Intake, exhaust, header are a few basic item for bolt-on, since it's an auto you won't see much in gain at the wheel though, and auto trans for 98-02 are very weak.
Old 10-10-2011, 09:21 AM
g22cd5's Avatar
Supper Moderator
also remember this when buying parts...
cheap
fast
reliable
...You can only have 2 of the 3.
Your biggest mod you can do to make your honda little bit faster will be a 5speed swap. Your not adding any power but your free up lost power that the auto eats up. You will all ways see a 20-30% drive train power loss.
If you want bang for buck nitrous will be your best bet. But you won't have the extra power all the time only by a press of a button.
But your accords weakest link is your auto trans. If you plan on putting down anymore power then 10hp I would do a 5speed swap. Then your not really held back by your trans. At the point you can turbo/juice it just without having trans issues.
If your not interested in doing a 5speed swap I would stick to the basics
a GOOD header
A GOOD intake
Ported intake manifold
Bigger TB port matched to the plenum
Exhaust (if you don't plan on getting a tune I would not do this mod. You will run rich all day every day)
Street tune
All that should yield you around 10hp
Old 10-11-2011, 06:52 PM
Pizzle_00's Avatar
I think I'm gonna go with a AEM Air Intake & Cat-Back Exhaust for now
Based on product descriptions and reviews, said they should gimme about 15 HP
Old 10-11-2011, 07:02 PM
g22cd5's Avatar
Supper Moderator
there is no way you will pull 15hp from a CAI and cat back. Maybe if you got a killer tune you might can get 10hp out of both of them. But with both thos mods you will get like 5-6hp
Old 10-11-2011, 09:35 PM
Even if you could get 15hp from CAI and catback, it won't be wheel horsepower but crank hp, you might see like 5hp increase at the wheel. Only a dyno machine can tell how much gain in whp, if you can get it done before and after the bolt-on, then you will know for sure how much gain in hp. You should be seeing around 114 whp stock for auto.
pace
04-17-2008 04:40 PM
YeuEmMaiMai
10-17-2006 04:32 AM
thunder_x
08-18-2006 02:48 AM
calenatar
04-17-2006 05:26 PM
dave118811
03-26-2006 11:09 PM
Quick Reply: More Power
