Multiple miss-fire problem - Help!!
Old Nov 13, 2011 | 08:58 PM
Marc D's Avatar
Default Multiple miss-fire problem - Help!!
I own a 1999 Accord 3.0 V-tech with about 200,000kms. The car has been well maintained with mostly OEM parts. I have an intermittent problem that I cannot figure out. It started as an occasional hesitation from a standstill. The up-stream O2 sensor was changed, but it did not correct the problem. Then ignition wires, cap, rotor & spark plugs were replaced with premium quality parts, still had the problem. A scan revealed multiple miss-fires on all cylinders. The igniter and ignition coil were changed, no solution. The EGR valve was changed 3 years ago, it was removed and inspected, no clogging.
The problem only appears when the engine is at operating temperature, and you do a lot of stop-start driving. It does not manifest itself at all when high-way driving, even after several hours. In stop-start driving, it becomes worse if you mash the accelerator. But you can still drive if you play with the pedal. Two garages and a dealership have not been able to figure it out.
Can someone help me?
Thanks, Marc D
Old Nov 15, 2011 | 12:57 AM
Hi Member..You started out your post's in the wrong forums, so I moved you over to here where your reading this now...Always try to post in the correct forums for answers.
Old Nov 15, 2011 | 08:43 AM
hondadude's Avatar
The EGR valve itself is not where the soot clogging occurs;
http://hondadude.webs.com/sb99085EGR.gif
I wouldn't worry about installing the "pipe kit", but clear the port where the intake manifold meets the channel from the EGR valve.
Old Nov 16, 2011 | 06:09 PM
Marc D's Avatar
Hey HondaDude,
Thanks for the reply. I checked the passage that leads from the EGR valve to the manifold and it looked clear. I will check again, (perhaps un-bolt it) and see if there is any clogging.
Thanks. Any other suggestions are most welcome.
HondaAccord91
Feb 6, 2013 05:03 PM
goss50
Oct 1, 2009 06:54 AM
evader
Sep 17, 2009 03:56 PM
Mdschmidt
Apr 17, 2009 06:53 PM
kr6g
Apr 2, 2007 05:38 PM
