Multiple problems on my 91 accord wagon
Old May 12, 2010 | 11:05 AM
djkaos23's Avatar
Default Multiple problems on my 91 accord wagon
I having multiple problems on my baby which is a 91 accord wagon. Hers a quick run down. 1. CEL comes on about 5 mins after starting/driving. 2. The green S light starts to flash after about 10 mins and continues to blink while im driving. 3. The idle seems to be high and it goes up and down for instant 2 rpms up to 3 rpms and back. 4. When i stop, i have to wait before i can start again because it wont start and also when it does it runs rough and acts if if its gonna cut off, like it bogs out.
My question is where should i start first. I really want to get her in tip top shape because im about to paint and change interior. Any help is TRULY AND GREATLY APPRCIATED.
Old May 12, 2010 | 11:27 AM
djkaos23's Avatar
did the cel check and got a code. it flashed slow 4 times then quick 3 times so that is code 43 correct??
Old May 19, 2010 | 12:19 AM
92hondawagonh22allmotor's Avatar
replace the o2 sensor and see what happens dont forget to reprograme. o2 sensor is a little spendy for that car.
Old May 19, 2010 | 02:02 AM
Also, count the S light flashes the same way you counted the check engine light flashes. The S light flashing means that the transmission computer detected a problem.
Old May 20, 2010 | 06:05 PM
djkaos23's Avatar
Update. I emove the FITV, IACV and cleaned both of them thoroughly. They were some clogged i had to smack myself. I also change the air filter. Gave her a crank and she fired right up. RPM's was high but went down after a min or so. I took her for a spin around a few corners and she shut down on me twice. BUt no flashing S light or check engine light (maybe i didnt drive long enough). So is the 02 sensor and possibly the main relay the culprits that need work/change. Also should i look into the distributor/spark plugs/wires etc and the fuel filter will be changed. Let me know. Thanks people
Old May 20, 2010 | 06:49 PM
A bad O2 sensor will not cause the car to stall out, so that isn't your problem.
Can you get the car to stall out by shaking the key when the engine is running?
You might as well do a full tuneup, so you can keep a proper maintenance schedule.
Replace the spark plugs with NGK spark plugs ZFR6F-11. They are about $2 each and can be found at any parts store. The distributor cap and rotor, I would go with OEM ones from a Honda dealership. Inspect the spark plug wires for cracks in the insulation. Replace with OEM or NGK plug wires, because they last for a long time.
Old May 21, 2010 | 10:56 AM
djkaos23's Avatar
Ok i had a hunch that i needed to check and/or maybe change the spark plugs. As far as the ditributor cap/rotor if i can get my hands on a oem honda one can i just go with the auto parts store have. i mean i will go for the best available.
Old May 21, 2010 | 11:31 AM
djkaos23's Avatar
i just went outside and cranked her up. She cranked right away. Now i had the paperclip in so i can check codes again. the flashing S light flased 6 different times.
1. 7 quick, 2. 8 quick, 3. 1 long , 4. 4 quick, 5. 1 quick, 6. 2 quick. What the hell does this mean cause im losing a lil faith here. anyone pleae lead me in the right direction.
Resatimm
Apr 28, 2016 05:56 PM
daver1100
May 8, 2014 02:41 PM
KvHotDog4
Nov 11, 2010 09:24 PM
importedminds
Sep 8, 2008 05:36 PM
BertMan
Jan 27, 2007 11:14 PM
