my accord wont pass smog?
Old Sep 9, 2012 | 09:14 PM
bingo296's Avatar
Default my accord wont pass smog?
i got a 2002 accord 2.3 ltr 4 banger and i cant seem to get it to pass the smog test here in nevada. i just replaced the cat and the lower sensor on the car. and it is still throwing a code for the cat being bad. my question is do i need to replace the upper sensor as well?
Old Sep 9, 2012 | 09:28 PM
doctorbee's Avatar
what brand did you replace the cat with? and the cat oxygen sensor?
you can use an infrared thermometer to check the cat's efficiency. It should be very hot, 400 to 600 degrees F
Old Sep 9, 2012 | 09:56 PM
What part of the test are you failing? CO, NOX,...?
bingo296
Oct 15, 2012 09:00 PM
1988 Honda Accord
Mar 15, 2012 06:53 AM
biggamejojo
May 24, 2011 11:58 PM
fusionstar
Jun 13, 2009 01:53 PM
thunder_x
Nov 6, 2006 08:26 PM
