My car shakes! Please help me!
Old Mar 23, 2011 | 08:21 AM
Joel_Cunnington12's Avatar
Originally Posted by trucknut88
My 2 cents??
Ill investigate but apparently everythign was checked when they did the clutch and fly change
Old Mar 23, 2011 | 09:17 AM
Nope.. the garage who fitted everything had the same idea and its not the pilot bearing. thats all tight
Old Mar 23, 2011 | 01:32 PM
dubjdub23's Avatar
I have the exact same problem, but mine is a 2005 LX Coupe, AT. It sucks. I hope you find out what it is so I can get mine fixed too.
Old Mar 23, 2011 | 02:20 PM
Ah Mate im glad im not alone! have a look at this.. its a very old post but its the same as our problem.. i cant find a solution any where!
2005 Honda Accord Vibration Felt From Drivetrain | CarComplaints.com
Old Mar 24, 2011 | 08:19 PM
JMH's Avatar
JMH
My 93 accord did something similiar a few weeks back just before i was getting ready to change out several suspension components. It would vibrate under load but over a wider range of speeds than you mention. When this occurred I got out of the vehicle to check it out, i grabbed the front wheel and pushed/pulled hard. I noticed some play, when i got back in the vibration stopped for a while. Anyways, I believe it was the CV axle, but I also replaced a broken coil, upper control arm & lower ball joint because they were all bad.
Old Mar 25, 2011 | 07:23 AM
Old Honda Dude's Avatar
An inner Cv joint could be the issue. Under load is when the inner joint would cause a vibration. I had a problem sort of like that. It turned out to be plugged EGR ports.
Old Mar 25, 2011 | 08:32 AM
  #17
thanks for the advise guys.. im getting a new Shaft and CV joins put on tomrrow and i will update.
Old Mar 30, 2011 | 12:13 PM
  #18
dubjdub23's Avatar
Anything come of your latest fixes?
Old May 1, 2011 | 09:13 AM
  #19
Hey everyone!! ALL FIXED@!@! it was the Near side CV-joint!! i cant beleive this wold make so mch vibration and movement bt it did!! Really HoPe everyone with the same Problem can fix theirs!!!
thanks for all the hel
P!!!
Old May 1, 2011 | 10:19 AM
  #20
Thanks for getting back, it will help those in the future. Glad to see it is resolved.
