my driver side low beam headlight has burned out 3 times
For some reason my driver side low beam headlight has burned out 3 times and in that time the passenger side low beam headlight hasn't burned out once. I've been using the one step down from the most expensive silvers stars which are I think the ZXE. Just doesn't make sense.
Pure speculation...
After a lot of people said the same thing on another board, it was suggested that adjusting the bump stops that control the position of the leading edge of the hood might do it. When you close the hood it hits these stops & maybe they're adjusted in a way that hits the lamps harder than usual??
My opinion is it is due to the use of the Silverstar bulbs.
https://www.hondaaccordforum.com/for...estions-51429/
captainrumdum
Aug 25, 2015 11:50 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
mngantung
Aug 5, 2006 02:22 PM
