is my rad shot? (new inst. questions inside)
Old Jan 23, 2008 | 07:53 AM
  #21
reinventingaxlrose's Avatar
Default RE: is my rad shot?
not sure if it's anti freeze or not. looks a little thick to be... i just picked up the rad already removed from the old vehicle and there was/is some of this stuff sitting in one of the bottom hoses. they just chopped the hoses when they removed the rad from the car. i'm going to clean it out before installing it anyway. i'm going to start the installation process in an hour or so. hopefully all goes well and I don't need any more parts as i'm in the middle of nowhere right now.i'll be back if i have any more questions :P thanks guys.
Old Jan 23, 2008 | 09:15 AM
  #22
falkore24's Avatar
Since you're in the middle of nowhere and you need an immediate fix, just stuff some paper toweling or a small piece of a rag in the tranny cooler lines. It should look like a single strip of baseboard, like what's inside the casing in a home. kinda like this:
Old Jan 23, 2008 | 02:43 PM
  #23
my old rad had caps to cover the two tranny lines. new problem though. stupid one. can't find the bleeder bolt?! i have the shop manual and the picture isn't much help at all...
Old Jan 25, 2008 | 09:36 AM
  #24
falkore24's Avatar
Don't you just run it for a while with the radiator cap off???
Old Jan 25, 2008 | 11:51 AM
  #25
The bleeder bolt is #13 on top of the thermostat housing.
Old Jan 25, 2008 | 01:29 PM
  #26
sir_nasty's Avatar
ORIGINAL: reinventingaxlrose
Not sure if this is the issue or not but I've seen where someone has taken that radiator stop leak and put it into the radiator which causes the fluid to change color slightly....
1994-Texas-LX
Aug 29, 2013 10:05 PM
ibettysman35773
Jul 6, 2013 07:14 AM
royzell
Sep 1, 2009 12:47 PM
piffmiester2006
Jun 4, 2007 10:49 AM
72mustang
Feb 12, 2006 10:16 PM
