Mysterious valve train issue...1991 accord
Old Jun 11, 2012 | 08:42 PM
NONYAMT's Avatar
Default Mysterious valve train issue...1991 accord
A mystery to me anyhow.The bottom end of this motor was rebuilt at 160,000,its at 194xxx now.The top end has had a tic at HIGH rpms right before you shift forever,recently the tic has turned into a annoying TAP at almost all rpm ranges,the weird thing is that it comes and goes,seems to get louder as it warms up.At cold idle the motor is SILENT.I pulled the valve cover and checked all the valve adjustments a couple needed tweeking but it had no effect on the mystery noise.I did notice that the springs that keep the rocker arms over the valves seemed weak,I can slide the rocker arm over off the valve stem with little effort,is this normal?Could this be the source,is one of the rockers working its way off the valve and tapping?Are these springs available so I can replace them?If any of you have adressed this issue Id appreciate your input!THANX!
Old Jun 11, 2012 | 09:18 PM
UhOh's Avatar
my '92 w/ 205,000 has tic in engine, esp seems when cool in AM.
... I'm not doing anything about it.
Interested if you figure out yours.
Old Jun 13, 2012 | 07:05 PM
NONYAMT's Avatar
nobody?
Old Jun 13, 2012 | 07:39 PM
My initial thought was for you to do a valve adjustment, but you already did that.
When the rocker is pushing down on the valve, is there still play?
lilwhiskeygurl
Mar 22, 2012 12:51 PM
nismoawan
Oct 13, 2011 11:40 PM
ariff
Feb 1, 2010 10:31 PM
onempty
Dec 1, 2008 07:18 PM
MALSR
Apr 24, 2007 01:40 PM
