91 Accord Mysterious issue
Old Mar 22, 2012 | 11:29 AM
lilwhiskeygurl's Avatar
Question 91 Accord Mysterious issue
I have a 91 accordex 5spd 4dr 4cyl. I recently bought the car and shortly after that it started doing this weird jerking/loss of motor power thing. After a few times of that it popped up code 43 (fuel supply system defective OR malfunctioning fuel supply system). I figured it being so old it probably needed a lil tlc and in the last month have cleaned the EGR Valve and IACV.
On top of that I have replaced these:
New Distributor(2x)
NGK Plugs
Honda Wires
Cap & Rotor
O2 Sensor (2x)
TPMS
Fuel Filter
Fuel Pump
ECM(2x)
Injectors
Today I discovered that the 02 sensor connnector is reading a higher ohms than it should. I read something about there being a wiring issue with the o2 sensor and somthing to do with a ground wire. I am at my wits end with trying to figure out what the problem is and it's costing me so much money too. Please help me if you can. Thank you for your time.
Old Mar 22, 2012 | 12:51 PM
I believe Code 43 means that fuel mixture is incorrect. This can happen for many reasons; o2 sensor, fuel pressure, intake air leak. Suggest inspecting for intake air leaks.
O2 sensor heater resistance will set a CEL code if it's faulty; open or shorted. Resistance measurements are notoriously variable.
NONYAMT
Jun 13, 2012 07:39 PM
Hurronnicane
Mar 29, 2012 12:19 PM
nismoawan
Oct 13, 2011 11:40 PM
snowbird117
Aug 14, 2011 12:33 PM
garretthes
Mar 8, 2010 11:54 AM
