Mysterious Brake issue
Old Jun 15, 2009 | 12:26 AM
garretthes's Avatar
Default Mysterious Brake issue
1996 Accord EX 243,000 miles
Here are the symptoms:
Occasionally the brake pedal will go to the floor with almost no stopping power, usually one wheel stops only. Happens more at slower speeds.
After pumping the brake pedal a few times the pedal is hard and brakes are great. They hold pressure and don't leak.
We have bled the entire system including the abs. It's NOT the master cylinder. I have replaced this 3 times.
The abs system works.
Old Jun 15, 2009 | 11:41 AM
00AccordLX5spd's Avatar
Registered User
Did you use a genuine Honda Master Cylinder? Why did you replace it 3 times?
Sounds like classic master cylinder failure to me...
Old Mar 7, 2010 | 02:30 PM
broke's Avatar
Default How do you bleed the ABS?
I didn't know you could bleed the ABS. I have almost the same problem, but I haven't done anything with the ABS.
Old Mar 7, 2010 | 06:10 PM
Broke, what car you got?
Beginning in 1998 there's no longer any separate bleeding for ABS.
Old Mar 8, 2010 | 07:49 AM
broke's Avatar
Mine is a 1996 Accord. I discovered that the ABS resevoir is below "min" level.
Old Mar 8, 2010 | 08:13 AM
broke's Avatar
I just added brake fluid (Dot 3). It took a while for the fluid to flow into the resevoir, but it is at max now. Should I bleed the ABS system? I would think there is a leak somewhere.
Old Mar 8, 2010 | 09:02 AM
broke's Avatar
edit...
Here's a link to some instructions I posted just above this.
https://www.hondaaccordforum.com/for...106#post198106
JimBlake
Wow! You're good. I saw the bleed screw, but I didn't want to do anything without being sure. If this doesn't fix it, what's the next step? Should I check for leaks? Thanks so much for your help!
Last edited by JimBlake; Mar 8, 2010 at 03:51 PM. Reason: don't know how to insert a post back here.
Old Mar 8, 2010 | 09:28 AM
YES, check for leaks.
You might have some plugs in the side of the modulator (not shown separately in that picture). I've heard about those leaking, but hasn't happened to me.
Another leak can be O-rings at the bottom of the accumulator (#23) or at the pump (#24).
We're getting away from the original poster's issue. Garretthes, what's new?
Old Mar 8, 2010 | 11:10 AM
deserthonda's Avatar
JIM........you should move it to DIY section ( How to bleed abs system,) I tried to but i cannot move graphics over there or i do not know how ,,
Old Mar 8, 2010 | 11:54 AM
AAAHHH my post is gone!
Just kidding, Desert. I'll write something up again over there. I've dissappeared a couple posts myself when I was figuring out how to move stuff.
OK, I re-wrote those instructions & put them in the DIY-Answers area.
NONYAMT
Jun 13, 2012 07:39 PM
lilwhiskeygurl
Mar 22, 2012 12:51 PM
nismoawan
Oct 13, 2011 11:40 PM
manah
Jan 17, 2008 06:54 PM
lilthads@hotmail.com
Jan 8, 2008 07:49 AM
