Need a fuel pressure adapter - where?
Old Mar 8, 2007 | 06:24 PM
cheggie's Avatar
Default Need a fuel pressure adapter - where?
I need to test the fuel pressure for my 91 Accord LX 5-spd, but I need an adapter for my fuel pressure gauge. I have 1/8" NPT male coming from the gauge, and I need to know where to plumb into the fuel rail/lines. Is there a commonly available part to adapt the rail to a ****** fitting or 1/8" NPT?
Old Mar 8, 2007 | 10:09 PM
Default RE: Need a fuel pressure adapter - where?
This requires a special banjo bolt adapter that I have not been able to find either. Haynes has a description in Accord manuals of how to make an adapter, but the procedure would require either a drill press or some very good nerves to drill a small hole longitudinally through a 1" bolt length. I've tried that before and it's not easy. The bolt is 12mm diameter x 1.25mm thread pitch, if you're game.
Honda apparently specializes in creating pressure ports that require unavailable adapters. Their transmissions have similar unavailable pressure adapter fittings.
Post if you find a suitable fitting.
basket_case
Jun 15, 2013 09:56 AM
eduard
May 9, 2013 12:11 AM
RobinsonRicer
Mar 20, 2013 07:33 AM
BigOBob
Jan 1, 2012 02:47 PM
piconrule
Jul 24, 2009 02:38 PM
