Need Help. Any suggestions??
Old Nov 19, 2010 | 08:24 PM
bozos_si's Avatar
Default Need Help. Any suggestions??
my 98 accord 5 speed speedomenter sometimes doesnt work. When it doesnt work it idles rough. Sometimes dies. It also lacks power. Almost seems like down shifting when you let off the gas when it is in gear. Sometimes when it isnt working the temp gauge will also bounce. Peg hot and then go down to normal. Any clue as to what this could be? I dont see how it could be the speed sensor just cause i dont know how the speed sensor could cause the idling problem and the car lacking power. Please let me know if you have any suggestions... Any help is great.
Thanks.
Old Nov 19, 2010 | 09:12 PM
Does the check engine light turn on or the D4 light start flashing?
Old Nov 19, 2010 | 09:29 PM
bozos_si's Avatar
check engine light is on already from a leak. i have a 5 speed so the d4 light does not come on.
Old Nov 19, 2010 | 09:42 PM
What is the code you are getting?
Old Nov 22, 2010 | 08:43 PM
bozos_si's Avatar
p1457. its a code that i had for a while now. I know it has nothing to do with the problem i have now.
Old Nov 22, 2010 | 10:29 PM
Checked it lately to see if you have any additional codes along with the P1457?
(I agree EVAP leak won't cause your current problems)
Old Nov 23, 2010 | 10:37 PM
bozos_si's Avatar
well i heard that it is the vss. how hard is this to replace in a 98 accord 4 door 5 speed ex manual? is it pretty easy to get at and do? anyone have any pictures?
Old Nov 23, 2010 | 11:03 PM
Thumbs up Hello Newer Member...
I think this might help you in your Quest on your question..
click the image...
Attached Thumbnails Need Help. Any suggestions??-imagesvss98accord.jpg   Need Help. Any suggestions??-imagesca95bw1d.jpg
Old Nov 24, 2010 | 01:13 PM
P1457 is a leak in the EVAP system, it has nothing to do with the VSS.
Did you read error codes lately to see whether you have any more in addition to P1457?
P0500 would be a problem with VSS, on a manual-trans car.
(P1791=VSS for an auto-trans car)
If you don't read a P0500, then the ECU seems to be getting a good signal from the VSS. I'm pretty sure in 1998 the VSS signal doesn't go to the speedometer. The speedometer is driven directly by the ECU.
Old Nov 24, 2010 | 01:22 PM
deserthonda's Avatar
never seen yet a bad vss cause a car to run rough and die .. any other codes stored in the ecu besides p1457 ??......Don't replace any parts till properly diagnosed
honda2k6
May 9, 2012 09:12 AM
1a9c9c9ord
Dec 12, 2006 12:07 AM
thunder_x
Sep 7, 2006 02:57 AM
guitargod33
Jul 24, 2006 10:39 AM
JT 03
May 7, 2006 11:58 PM
