need help car wont start
ok so my car 1998 honda accord ex wont start, nothing electrical will come on a few days ago i got a new battery i put it in it would turn over fine. i come back a few days later to find that nothing will come on no clock nothing so i checked the fuses checked all my connections and now im just lost. can someone tell me what to do?
Was it OK before you put the new battery in?
Look for loose/dirty/corroded connections at the OTHER ends of both battery cables.
Have someone try starting while you hit the starter with a broom-handle. If that works, you need a new starter (or rebuild yours).
If it was the starter, all the electrical components and dash lights would be working... And they are not. Have the battery tested. May be a dud. Also could have a bad alternator. Were you driving the car those days in between when you bought the new battery and it going dead?
New batteries can be bad right out of the box. Cables can be corroded where the cable itself crimps into the end-connector. Bad connection at the fusebox so EVERYTHING is affected?
if it started ok after installing new battery ,, perhaps you left something on ?? dead battery now ?? did you try jump starting it ?? did you have new battery tested??
did you drive car after replacing battery?? car been starting ok for few days ??have charging system tested,, possible bad alternator,?? possible electrical drain ??
the way it sounds is that you replaced the battery, turned over ok,, you left and came back few days later and nothing works
how did you test the battery ?? is it fully charged,,,,,,,,,,is it over 9.8 volts under load ??
sometimes a battery bought at a part store sits for a long while and could be not fully charged,,,,,,did they charge it for you when you bought it ?? ,,car started ok after you installed new battery ,, correct ??
no offense but i feel like i have to pull words out of your mouth ............give us all the info .
Jeoeljefe2012
Apr 10, 2012 11:40 AM
fastdart360
Jan 25, 2008 09:19 AM
