Need help diagnosing*
Old Aug 11, 2012 | 04:55 PM
Sobel's Avatar
Default Need help diagnosing*
1999 accord, 3L, *6 cylinder, *EX , Auto, over 180,000 miles
About one out of five times I go to start my car it won't start. Then i wait a few seconds try it again and it works. This has been going on for about a week. The check engine light blinks on for a moment as I start the car, then goes away. it's not the starter because I can hear it turning strong. And it's not the battery. *The last time it happened I hit the gas peddle while revving the engine and got it to start that way.*
If anyone can help diagnose the problem that would be greatly appreciated.
Old Aug 11, 2012 | 06:11 PM
When you attempt to start turn keyswitch to On and listen. You should hear main fuel relay (MFR) under the dash click and fuel pump in fuel tank run for 2-3 secs and cut off w/ Check Engine Light.
When you don't hear these sounds, no start is likely. Cause is usually faulty MFR.
Old Aug 13, 2012 | 09:42 AM
I think the common type of failure of the main relay results in the relay clicking but the pump doesn't run.
Old Aug 13, 2012 | 10:04 AM
doctorbee's Avatar
does the green immobilizer light flash when it doesn't start?
sschnei
Jun 21, 2012 08:40 PM
lvs4rock
Oct 28, 2010 01:46 AM
razcob
Dec 30, 2007 10:44 AM
james.walters
Mar 13, 2007 04:43 PM
sdemasi
Oct 22, 2006 11:29 PM
