Need help finding ABS Diag Connector
Old Dec 21, 2006 | 05:16 PM
wietgr's Avatar
Default Need help finding ABS Diag Connector
I own a 1994 EX 4dr, my ABS light is on and i have been trying to find the diagnostic connector. the shop manual says that it is loctaed right underneath the glove box. I looked but it is not there i removed the glove box and still could not locate it. Its is a 2 terminal orange connector that i need to bridge to get the flash code. Please help if you have any handy info, thanks!
Old Dec 21, 2006 | 05:28 PM
sir_nasty's Avatar
Default RE: Need help finding ABS Diag Connector
I believe it's behind that passenger side kick panel... let me double check but I'm almost positive it's there... I know the check engine light is there....
Old Dec 21, 2006 | 07:12 PM
hondadude's Avatar
Top of the passenger side kick panel, then look toward under the glove box.
BLUE 2 pin connector, might be in a holder of sorts next to a 3 pin connector.
jumper that 2 pin connector, turn on the ignition.
The ABS has a two part flash code, first it flashes the major part of the system, then the sub component.
Old Dec 26, 2006 | 05:07 PM
wietgr's Avatar
i looked there and still can not locate it![:@]i did however see the abs module... could it be behindthe module?
Old Dec 26, 2006 | 06:44 PM
sir_nasty's Avatar
are you sure that it was the abs module you saw and not the holder thing that he was talking about? the second possibility, it somehow slid down behind that kick panel.... If you can then post us a picture of the module you are talking about and the general area under there....
Old Jan 2, 2007 | 03:58 PM
wietgr's Avatar
Ifinally found the connector, bridged it andI belive it is a code 12. one flash then two. does this code mean?
Old Jan 2, 2007 | 04:17 PM
sir_nasty's Avatar
12- Throttle Position sensor (TPS) or circuit
the shorter flashes are one and the longer one's are ten's, if it is in fact 12 then it could be a vacuum line problem (check for any vacuum leaks).... search the forum for OBD 1 codes or just "trouble codes" and there is a better explination in there...
Old Jan 2, 2007 | 04:31 PM
wietgr's Avatar
Idoubt its the TPS, but i am sure the code is a 12, one long flash follwed by two short flashes. I belive the pump kotor is the cause. which wires do i jump to check for motor operation?
Old Jan 17, 2007 | 06:00 PM
walker111's Avatar
ORIGINAL: wietgr
1-2 is the pump motor. Check the 40 amp fuse in the ABS fusebox, now pull the the relay and jump the large connectors to see if the pump kicks on..
Old Jan 17, 2007 | 10:23 PM
hondadude's Avatar
basket_case
May 10, 2015 06:06 PM
JEB0007
May 14, 2011 02:50 AM
live2rice
Oct 13, 2008 04:25 PM
Troy1988
Jul 3, 2008 06:26 PM
jorge
Sep 17, 2007 08:18 AM
