jumping ABS connector
Old Oct 13, 2008 | 03:16 PM
Default jumping ABS connector
is it possible to jump the ABS light like it is the CEL. I have a ABS light for what i believe is a wheel speed sensor but i want to make sure before i go replacing things. but since i have a obd1 ecu in a obd2 car i'm dont know if autozone could read what its for with the obd2 port.
Old Oct 13, 2008 | 04:11 PM
Default RE: jumping ABS connector
For an OBD-1 car, you jump the same SCS connector as if you wanted ECU codes. The ABS lamp flashes instead (or in addition to) the CEL.
Im not sure if/how the ECU talks to the ABS controller. If the SCS connectoris simplywired in parallelto BOTH computers, then youre OK. But if the OBD-1 ECU doesnt know how to talk with the OBD-2 ABS computer, then ????
AutoZone probably could not read ABS errors, even if you still had the OBD-2 ECU.
Old Oct 13, 2008 | 04:14 PM
well i jumped the connector I use for the CEL codes but the abs did not flash, if I cant figure it out bye bye abs system
Old Oct 13, 2008 | 04:25 PM
Got a wiring drawing? Look for a connection between the SCS connector & the ABS controller. Most likely, you didnt maintain that circuit when you did the OBD-1 to OBD-2 harness conversion.
If there is ONLY a data connection between the 2 computers, then youre SOL.
basket_case
May 10, 2015 06:06 PM
jorge
Sep 17, 2007 08:18 AM
wietgr
Jan 17, 2007 10:23 PM
iridebmx33
Apr 6, 2006 01:41 AM
badmrb
Dec 6, 2005 03:16 PM
