NEED HELP WITH O2 SENSOR!!!!
Old Sep 7, 2008 | 03:10 PM
dmost30
Default NEED HELP WITH O2 SENSOR!!!!
i have a 2003 accord lx 4 cylinder. The diagnostics report stated that the heating sensor was bad in bank 1 sensor 2. I was told the my car has three O2 sensors. My question is where are all three located and which one is bank 1 sensor 2?
Thank you for any advice
Old Sep 7, 2008 | 03:43 PM
Default RE: NEED HELP WITH O2 SENSOR!!!!
Most 4-cylinders have only two O2 sensors, one ahead of cat and one behind the cat. In my reference book on OBD2, Bank 1 Sensor 2 is the O2 sensor aft of the catalytic converter.
You may need to carefully elevate front and rear on jack stands to access the O2 sensor. I have also elevated one side of the car to do this job also.
You need a O2 sensor socket or 19mm combination wrench to remove the O2 sensor. They can be very tight. Warming the engine for 5 mins may help to breakthe sensor loose. I've had to use a hammer on the combination wrench to break them loose.
Old Sep 7, 2008 | 06:49 PM
dmost30
So a 2003 accord lx definetly has 2 O2 SENSORS? Does anyone know where exactly they are located? Upon looking into prices i found that theres a upstream and a downstream, which one is bank1 sonsor2?
Old Sep 7, 2008 | 08:17 PM
Asked and answered. Read my previous note.
pondrun
Nov 8, 2021 09:40 AM
choi
Apr 18, 2014 08:43 PM
dmost30
Sep 8, 2008 12:42 AM
dmost30
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
