Need a little help - coolant lines
Old Nov 8, 2011 | 03:04 PM
94F22B2's Avatar
Default Need a little help - coolant lines
My latest project...
1994 Accord EX - F22B2/Auto - 200k+ miles
I'm just finishing up Engine R&R. I started after the original head was removed. So I didn't have the chance to recall where everything was hooked up.
1. The coolant pipe at the rear of the engine. There is a small nipple in the middle. Appears to be a 1/4 - 3/8" hose attaches to it.
I'd like to know where that goes.
I found a vacuum diagram from autozones website to help on that part.
All looks good so far.
New timing belt/tensioners/water pump/oil pan gasket.
New motor mounts (pricey)
Have new fluids/filters...
Thanks in advance.
Old Nov 8, 2011 | 04:34 PM
You can download a manual from Online Manuals post in DIY forum.
Try following link inside the quotes:
"http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgr y2=1994&catcgry3=4DR+EX&catcgry4=KA4AT&catcgry5=WA TER+HOSE+%281%29"
Old Nov 17, 2011 | 10:58 AM
94F22B2's Avatar
For a quick answer like I was needing at the time I'll post it here.
Small Coolant hose goes to the upper intake/appears to be some type of electronic valve maybe? Not sure. Maybe someone can clarify.
Thanks!
Old Nov 17, 2011 | 03:05 PM
I'm not positive but it is more than likely the idle air control valve.
Old Nov 17, 2011 | 03:28 PM
94F22B2's Avatar
If it is the EACV then those would be vacuum lines. Not coolant.
Old Nov 17, 2011 | 09:15 PM
The IACV or EACV does have coolant lines that pass through it to heat to operating temp quickly.
You need a manual.
Old Nov 18, 2011 | 09:13 AM
94F22B2's Avatar
texashonda, That makes a lot of sense. The hose fits perfectly down to the coolant pipe.
brandon0409
Feb 15, 2014 06:36 PM
OLDERTUNER94
Aug 13, 2012 06:30 PM
jrcastro
Jun 24, 2006 12:45 AM
96Cord
Sep 29, 2005 03:34 PM
