need some help
Old Dec 30, 2008 | 06:28 PM
jamrock's Avatar
Default need some help
hey i have a 94 accord and the intake manifold gasket is leaking.. does any one know it the wold cause a code 43 to keep coming up. also i wana do a brake conversion does any one know the list of parts i would need
Old Dec 30, 2008 | 08:24 PM
hondadude's Avatar
Default RE: need some help
Code 43 is set by way of the O2 sensor 'out of parameters';
So to answer the question....YES
Old Dec 30, 2008 | 08:41 PM
jamrock's Avatar
so wat about the brake conversion im trying to do a hub and rotor conversion i check the diy and i only seen the conversion for the cb7 is the parts for the cd5 the same?
Old Dec 30, 2008 | 10:00 PM
hondadude's Avatar
ORIGINAL: jamrock
You'll need to find out that info from a yarder, in 18 years of dealership level work we never did that conversion; We also know that CD7 CB5 gamesand GENs, is not theway to get accurateinformation.
Old Dec 30, 2008 | 10:04 PM
finch13's Avatar
ORIGINAL: jamrock
Do a search, that is one of the most popular mods out there and there are plenty of parts list floating around. CB7 and CD5 are not the same gen of Accord, you need to look into 5th gen rear discs from the EX for 4 lugs and Acura CL hubs and rotors for 5 lugs.
Old Dec 31, 2008 | 06:47 AM
jamrock's Avatar
im not trying to a rear end conversion im trying to conver the front end conversion so i wont have to take the whole knuckle off to change the front rotors
Old Dec 31, 2008 | 02:47 PM
www.tasauto.com has a the whole kit (hub, bearing, rotor, pads) for ~$350.
I think that the hub is from a 98 acura CL 2.3L. You can google hub over the rotor conversion and find a lot of information.
Brian
Jul 17, 2006 10:31 PM
19accord92
Apr 15, 2006 08:50 PM
HondaLawgik
Feb 8, 2006 02:21 PM
blazedg
Jul 5, 2005 07:52 PM
blacktopracer
May 11, 2005 10:11 PM
